free website stats program Squeaky Sportster | Harley Davidson Forums
Squeaky Sportster
Joe1957
1986 Sportster squeak or chirp sound coming from what sounds like the front of the primary side. Checked and loosen the primary chain a little and checked and loosened the clutch a little no change in noise. Not as bad when cold and clutch in or not makes no difference. Does get worst at higher RPMs but does not seem to be in direct proportions to the RPMs
Are you sure it's from the primary side. My ride squeaks as well, but that's from the belt. I'm not on my own with this problem, it's quite common apparently.
Get someone to push it while you listen.
Jak...
Sometimes a squeak or a chirp can be a small head gasket leak.
Could this be an exhaust leak or a heat shield loose? Check the bolts in the upper motor mount as well
