free website stats program Sputtering | Harley Davidson Forums
Sputtering
Redman1
I have a 2012 Road Glide Ultra I have changed oil-stator-regulator-air filter bike was running fine for about 4 hours now bike is sputtering and light is coming on can somebody tell me what you think problem is
Have you checked for codes? Which light is coming on?
As Don said check for codes, codes may tell you what the problem may be.
Take a look here in the self help section.
2004- 2015 Harley Trouble codes in depth reading
If you haven't read your codes check here.
Yes I did that stator is good regulator is good I'm asking what else you think problem could be
The codes are vss sensors high voltage - temperature controlled sensor
Check the head sensor in the front head behind your horn
