Spot lights
Discussion in 'General Harley Davidson Topic' started by KenBratt, May 2, 2012.
  1. KenBratt
    KenBratt Member
    25
    Did my first real night riding about a week ago. Playing with the high/low beams I noticed that whenever I put on the high beam my spots go out - they only run with the low beam. Is this normal? Don't I need to see close to the bike with my highbeams on (sarcasm). Is there some way to over ride this?
  2. bcortani
    bcortani Active Member
    392
    3
    there is a way to overide this but you will need someone other than me to explain it. If you check the self help tips there are a couple of threads on it with wiring diagram and all.
  3. KenBratt
    KenBratt Member
    25
    thank you
  4. TXMikey
    TXMikey Junior Member
    477
    If you don't want to splice the wiring, and prefer a plug and play option, H-D now offers an adapter. It's fairly easy to install, and works great. It's part number 69200441.
  5. gator508
    gator508 Well-Known Member
    2,760
    179
    Isn't it funny how HD makes a solution for an application that should already be in place...JMO
  6. rhino 2
    rhino 2 Active Member
    182
    It's normal' And by law the spots [aka fogs] have to turn off when the hi beams are turned on.
  7. Iceman24
    Iceman24 Well-Known Member
    3,266
    23
    Also, check w/your local DMV because running spots on high-beam could be illegal where you live...
  8. KenBratt
    KenBratt Member
    25
    Thanks for the info, I will check on the legality of running spots with a high beam. You guys have all been great.
  9. llharr
    llharr Member
    84
    I ordered this part from a harley dealer in Pensacola Fl. on April 11,2012. It has not come in yet. Makes me wonder if they the really ordered the part to start with. Going to give them one more week, if it don't come in I am going to ask for my money back:panic
  10. TXMikey
    477
    I would definitely check on it. All the dealers around here have the part in stock, and displayed on the floor with other accessories.
