free website stats program Sportser Transmissions Stuck In Gear | Harley Davidson Forums
J
Jack Klarich
Guest
First off, no new parts were needed!
Second, you will need to disengage BOTH of the miniature tension springs to get the wishbone arms properly set so that they are engaging the little cogs on the drum. More than likely, only one of these arms jumped the pin, and it won't look like anything is wrong at a glance. But on closer inspection you will notice the arm that jumped the pin, will have little to no tension on that spring.
Once you've got the arms set, re-connect the tension springs, put it all back together, add crank-case oil, adjust the chain tension/clutch and you should be good to go.
Happy rides!
This is a very good tech tip written by member Ash - B
