spitting oil
Discussion in 'General Harley Davidson Topic' started by ROOT BEER KING, Dec 21, 2011.
  1. RUSHMORE_14
    RUSHMORE_14 Junior Member
    538
    Ok,
    Did a stage one myself last spring. All Vance and Hines stuff. I keep finding little drops of oil on my gas tank(underside) above the AC after my rides. I have the VH naked with the HD Nostalgic cover (oval) and True Duals on 09 Heritage.
    Did not call VH yet, figured I'd hit you guys first.
    Thanks
  2. dbmg
    dbmg Guest
    Might there be a breather tube that needs hooked up????
  3. glider
    Check the "O" rings on the back of the legs where they mount to the cylinder heads.
  4. Jack Klarich
    Also check the breather hoses, some times they will collapse, or get pinched
  5. JerryL
    JerryL Member
    77
    Every open type breather I have ever added to my Harleys has puked a little oil out of the breather, but only if I got on it pretty hard.
  6. glider
    Have you checked the oil level to see if it may be a bit overfilled?
