My speedometer will jump around while in idle or just not work at all. What can I check?
C chiefchuck New Member May 24, 2010 #1 My speedometer will jump around while in idle or just not work at all. What can I check?
G glider Veteran Member May 24, 2010 #2 You can start here... Speed Sensor Pickup Problem Symptoms - Harley Davidson Community
B bigsteve799 New Member Jun 1, 2010 #3 check battery voltage with meter while slowly increasing rpms.should not go over 16ish volts. does speedo shut down?if it does its volt regulator in front of frame.good luck
G glider Veteran Member Jun 1, 2010 #4 bigsteve799 said: check battery voltage with meter while slowly increasing rpms.should not go over 16ish volts. Click to expand... Should never see more than 14.7 volts or you have a problem.
