speedo way off after wheel change
Discussion in 'Wheels' started by nascar7613, Jul 3, 2014.
  1. nascar7613
    nascar7613 Active Member
    241
    38
    5
    I have a 1995 Bad Boy. Changed out the front wheel to a 21" Now my speedo pegs out at low speed. It has a wheel driven cable type speedo. Is there a different speedo drive I can install to correct the problem or is there a gear kit to install in my speedo drive?
  2. Breeze3at
    Breeze3at Well-Known Member
    4,926
    224
    If your stock front wheel was 19", you need to get the speedo drive unit for a 21" front wheel. Dyna Wide Glide, or Softail Custom probably.
  3. dbmg
    dbmg Guest
    Check with dealer you might be able to change out cable gears...
  4. tourbox
    tourbox Senior Member
    1,902
    173
    Looking at the OEM parts page it came with a 21" wheel originally. What size was on it before the change? Soft Tails have a different speedo ratio than say a WG. I believe the WG is a 2/1 ratio and a Soft Tail is 2240:60 ratio. I don't know for sure what your speedo unit ratio is though. May someone here does or your local HD shop does.
    tourbox
  5. fin_676
    5,788
    153
    287
    The fxstc softail custom and fxdwg dyna wide glide both come with a 21" wheel and are both fitted with 67120-84b speedo drive unit the part number is from the 93-94 parts list that would be my best guess of what may be the best speedo drive unit
