Speedo probs
Discussion in 'Electrical' started by gatorwalt, Jul 26, 2008.
  1. gatorwalt
    gatorwalt New Member
    On my 01 Ultra, speedo keeps dropping down to zero, while riding. Sometimes it stays down, but mostly pops back up to speed.
    I pulled speedo sensor and cleaned it off, but no help. Any ideas?
    Thanks
    50
    Many times just cleaning the sensor doesn't help, replacement is the only solution. They run about $52
  3. Marks-Sportster
    Marks-Sportster Member
    25
    Did you notice if the backlight goes out at the same time? Funny thing, for the first time tonight I noticed my (98 Sporty) speedo went to zero, odometer went blank and light was out. After about 5 seconds it all came back on as if I just turned the ignition on (trip meter was still correct). I thought maybe a fuse had gone until it fixed itself....
    It may be worth checking if you had the same problem, as it suggests a lack of power rather than the sensor. nothing worse than an intermittent electrical problem.
