free website stats program speedo not working | Harley Davidson Forums
speedo not working
Start by telling us what model and year Harley you have, if electronic or cable operated speedo and if stock or after market, what you have done to the bike lately that could impact the speedo, fuses and grounding wires checked, etc. The more info you can provide the more likely someone can help.
Oh that would help huh ? Its a 1999 Dyna wide glide, doesnt have a speedo cable so im sure its electronic . Thanks
Thanks, helps a great deal.
If the speedo is receiving power and seems to otherwise work, the issue most likely is with the Vehicle Speed Sensor located on the transmission just behind the top cover. They can quit working if metal fragments collect on it.
If you can get to it, remove the mounting screw and clean it off. Reinstall and you should be good to go. But if that doesn't work you'll need to replace it. That involves removal of the battery and tray and the seat as the electrical plug is hidden there.
But if the speedo shows no sign of working you'll need to check the fuses, grounding, battery, and the plug to the unit. There remains a remote chance the speedo unit itself has gone south, but that unlikely.
If you don't have a Service Manual, get one. Best investment you can make.
