ZZroadking
Well I was driving my 05 RK Classic and noticed the speedo quit. It was hot out and the engine was quite hot. I started to pull over and it stalled. OK, I restarted and it worked again. Changed the oil thinking it could help as it was old,next day I drove on the hwy 2 hrs @ 72 degrees and no issues. Later in the city it started again (speedo) and the engine was running HOT. I would pull over and restart and would work again. Took it on the hwy at appr 58 temp rode 20 min it quit again, this time the engine light came on. I am thinking it came on as it was in the process of stalling. The engine also sounded rough like missing Vibrating. Speedo kept quitting all the way home. I would pull over and restart with no probs (can't afford a ticket from the Mounties!). As well the cruise would not work (on HWY) when speedo quit. The ODO does not work as well. I believe the turn signals also would not cancel either.
Sick pls help...
Sick pls help...
