P paulmack Active Member Oct 29, 2009 #1 Does the speed sensor wire directly into the ECM connector or does it have a connector on the end of the cable? If it does have a seperate connector where is it located?
G glider Veteran Member Oct 29, 2009 #2 Most things have a connector inline and are not wired directly to the ECM. If you follow the wire on the VSS, you'll find the plug.
S stuart1270 Member Oct 29, 2009 #3 glider said: Most things have a connector inline and are not wired directly to the ECM. If you follow the wire on the VSS, you'll find the plug. Click to expand... I helped a friend with a 2005 road king the speed sensor was connected to a separate connector before it went to the ECM
