spark plugs
Discussion in 'Touring Models' started by tdj45, Mar 30, 2010.
  1. tdj45
    tdj45 Member
    71
    anybody know who makes H-D spark plugs.
  2. BUBBIE
    BUBBIE Well-Known Member
    4,974
    125
    I THOUGHT CHAMPION MADE THE PLUGS FOR HARLEY......
  3. glider
    50
    I believe Bubbie is right here.
    signed....glider:D
  4. alford 56
    alford 56 Member
    17
    Don"t know who makes harley plugs ,but do yourself a favor and use e3's instead. You won't be disapointed E3 .36 plugs for evo engines.To be sure go to e3 site and check the cross reference chart for champion plugs.
  5. glider
    50
    The stock HD plugs are all that's needed for these engines. Replacing the plugs with the fancy plugs is a waste of money and makes no difference in performance with a basically stock engine. Also indexing the plugs on a stock engine will not show any improvement that is noticable. Leave the fancy tricks to the racing crowd.
  6. Iceman24
    Iceman24 Well-Known Member
    3,266
    23
    Yep, HD plugs are one of the few things your dealership doesn't mark-up too bad. Best to go w/the stock HD set - your pocketbook will be better off for it.
  7. alford 56
    alford 56 Member
    17
    When your looking for performance and efficiency, every little bit helps.
  8. Hoople
    Hoople Account Removed
    7,198
    34
    Looking closely at the stock Harley plugs (6R12 #32362-04) they sure do have every tell tale sign of being made by Champion.
    Don't know if same holds true for the Screaming Eagle performance plugs.
  9. Jack Klarich
    They are , but made to H D specs, I got this from a Champion rep at a tune up class, Very Good Hoop
  10. Bud White
    3,270
    Champion makes the non platinum plugs they are the same plugs as normal champions the rumor of special specs for hd how can you special spec a plug anyways is a not true
