spark plug indexing?
Discussion in 'Other Service and Maintenance' started by rydahog, Jul 2, 2009.
  1. rydahog
    rydahog Active Member
    236
    Anyone check their spark plug indexing when changing plugs?
    What index washers used? any other alternative. thanks ryd :D
  2. Bud White
    3,270
    on a stock bike and even semi modded .. waste of time
  3. glider
    Waste of time and money on a street bike, very marginal even on a drag bike.
  4. dangerdan
    dangerdan Junior Member
    922
    I was curious about this , so I looked it up.
    The idea of indexing is to position the spark plug so that its gap is facing the center of the cylinder, angled slightly toward the exhaust valve. This is important because, as the piston approaches TDC, the air/fuel charge is being compressed. The charge or "mixture" is being forced toward the area of the spark plug—and normally, the exhaust valve. The speed of this force inside the combustion chamber may surpasses supersonic speeds.
    When 1/4 mile times are measured in 1/1000 of a second, every bit helps and that includes marginal ones. This could make the differnce between winning and loosing.
  5. rydahog
    236
    ok thanks for the info..:) i won't be doing any 1/4 mile runs in the near future. so leave well enough alone and be happy with my 44-47 mi per gallon and sweet sound that my bike makes now!! :)
  6. dangerdan
    922
    Ok I missunderstood this. I thought a new pug hole was drilled into the heads to get at the sweet spot.
    I missed the part about only using a washer underneath the plug.
    Smitty I agree with you, total waste of time.
  7. glider
    They say if you do the plug indexing and use one of those magnetic collars around the fuel line to align the molecules in the fuel that you can dilute the fuel with 50% water and get over 74 MPG on any V Twin.:D
  8. dangerdan
    922
    You got the link for that magnetic collar.
    :bigsmiley22::bigsmiley22::bigsmiley22:
    Ok, point made.
  9. Bud White
    3,270
    I think using a sperated water injector would bump ya to 100 MPG
    Ask and you will receive
    - Harbor Freight Tools - Quality Tools at the Lowest Prices :D:bigsmiley22:
  10. HarleyHarry
    HarleyHarry Banned
    548
    What type of snorkle would I have to use for that?
    When running your bike with the injector as you suggested would you not measure in knots (KPG)?:small3d004:
