Sounds like its missing
Discussion in 'Touring Models' started by Fourdogs, Oct 21, 2009.
  1. Fourdogs
    Fourdogs Junior Member
    805
    3
    Ok heres the story. I have a 2004 RK. Has the 96 stage 2 upgrade. Runs a power commander II . Does not set any codes. As you can hear however sound like its missing. Will settle out in anywheres from 2 to sometimes as much as 7/8 minutes. Here pics of the plugs front and read cylinders. Also ya can hear it if I did this properly. What cha guys think? plug wires ? oh yeah its got 54,000 plus miles on her.
    YouTube - sound like its missing big time
    jpg.gif Front Cylinder.jpg (34.1 KB)
    jpg.gif rear cylinder.jpg (28.4 KB)
    50
    Plug tips or wire ends loose? Find out which cylinder it is and chedk the resistance in the plug wire for that cylinder. Plugs look good but it could be an internal short that clears with more heat. Tune it up and it will probably run fine, plugs and wires, remember it's an 04 and have you changed the wires yet?
    Is it a 96 or a 95 (typo)
    Always photograph a plug showing the rear of the ground strap to identify the heat range of the plug as being right.
    Try it with the PC disconnected?
    Watch for the deposits on the ground strap of the left pic too.
  3. Jack Klarich
    I agree with Glider I would start simple with new wires and see how it runs
  4. B-1B_Guy
    B-1B_Guy Junior Member
    556
    I'd say you definately have a miss there. I'm suprised one of the plugs wasn't wet or very dark. Plugs and wires are cheap....start there. Magnecor makes a great plug wire.
  5. Fourdogs
    805
    3
    Thank you gentleman...ok will replace plugs and wires...I have never replaced the plug wires. so that will be the first step. Then of course plugs as well. BTW the plugs had 4,327 miles on them. Will let y'all know what happens.
  6. glider
    50
    Have to be careful with aftermarket wires because of the ION sensing in these bikes. It can set a code.
  7. NEWHD74FAN
    8,191
    98
    19
    While you are replacing the wires and plugs (hopefully just use the stock HD ones, they are fine for stocker applications and for ION sensing as Glider says)...replace the plastic flip clips...they get brittle and crumble (I have a 2004 too...) and wires should come already "pre-dressed" with possibly all the protective plastic sheathng and boots assembled for just quick plug and play replacement...check with the dealer to be sure.
