Sound or Power
Discussion in 'Engine, Fuel and Exhaust' started by kabory, Sep 29, 2016.
Would you choose sound or power for a head pipe ?
  1. Power
    5 vote(s)
    83.3%
  2. Sound
    1 vote(s)
    16.7%
  1. kabory
    kabory Active Member
    125
    5
    Hello all,
    I traded my 11 wide glide for a 16 Road Glide Special. I am researching full exhaust. I am undecided on going with Dresser Duals or Power Duals.
    I have decided on staying with dual exhaust and all products will be V&H
    FP3
    Naked Air Filter
    Monster Rounds exhaust
    Dresser or Power Duals
    Which would you or have you choosen ?
    Power
    Sound
    Jack Klarich likes this.
  2. Jeff Klarich
    4,843
    103
    496
    I'd opt for power, getting too old for the noise.o_O
  3. jamesearl
    jamesearl Senior Member
    1,894
    223
    I wonder if you had loud pipes on the FXDWG.They can get annoying,especially on long rides.But if your used to them.Either one will be louder than stock,right?
  4. Jack Klarich
    Loud DOES not always mean more power
    Length of pipe , diameter baffles and cylinder fill is where you get your power, Heat helps scavenging the exhaust based on valve overlap, and size of cylinders, dome of heads etc, Too much heat can be bad thing Your ride u decide I may be wrong but I do have an exhaust formula written by Jerry Branch;)
  5. dbmg
    dbmg Guest
    Noise is very tiring. The fact that now you have a great touring bike I would advise to ride it stock and see if you can enjoy it as is. I had Rush mufflers on 2008 EG for a couple years and could not take the noise and headaches any more. Reinstalled O.E. mufflers and have doubled my riding time in the saddle. And by the way the addition of a air cleaner and full exhaust is only going to add approx. 10-15 additional H.P. Be sure that if you move forward you have a matched set so that bike performs flawlessly. So as Jack stated it your ride you decide.
  6. tourbox
    tourbox Senior Member
    1,902
    173
    I would have to agree with Jeff in post #2. I'm getting too old also(lol).
    tourbox
    Jack Klarich and Jeff Klarich like this.
  7. kabory
    125
    5
    Not talking about loud, talking about sound. Dressers or true duals give you that traditional Harley sound, where you can hear each cylinder. The new Power duals or Tru X head pipes, mix the sound from both cylinders and it is not as pronounced, but you do get the advantage of extra power. So I will rephrase the question.
    Would you sacrifice the Harley sound for a small gain in power.
  8. dbmg
    dbmg Guest
    The answer would be is the upgrade also going to give financial satisfaction also.
  9. jamesearl
    1,894
    223
    My bike is stock,I think it sounds like a Harley,I mean it has a Harley badge on the tank and everything.;)
  10. joel
    joel Senior Member
    1,068
    142
    I have 4 inch Rineharts that I took off my prev ultra thinking I was going to put them on the 15 but than decided to just leave the bike stock, maybe as I get older I lean more to a quieter ride, most of them are in the 700 mile 2 or 3 day trips and music has become my friend and the deap sound from the Rineharts as nice as it is, may just stay in my past.
    But extra sound from after market pipes do get the attention from someone drifting into my lane, so I guess I'm on the fence on this one.
    Thanks for starting this thread.
