sound coming from front of motor? any help
Discussion in 'Softail Models' started by Mustang, Jun 15, 2009.
  1. Mustang
    Mustang New Member
    Yesterday i was riding and started hearing a grumbling noises from the front lower part of the motor? When iam on the gas it seems to go away, when i stop and pull in clutch it comes back, also make the nosies in neutral. Any ideas of what it might be or any way to check to find out any and all sugestion would be great. Bike is a 2004 softail
  2. dolt
    dolt Senior Member
    2,172
    103
    333
    Check the compensator sprocket nut; it may be coming loose.
  3. glider
    I second the compensator and while you are in there check the chain tension.
  4. TQuentin1
    4,737
    142
    Ditto.
    Happened to my '03 UC. If you do not get to it quickly, the rotor will wallow around on the stator and something is gonna tear up. In my case, it was the teeth on the inside of the rotor hole that slide onto the drive shaft. Drive shaft sheared those all off. After I fixed it, the stator fried in a few weeks. That messed up the VR.
    So, "git 'er done"!!
  5. Mustang
    Mustang New Member
    Thanks for the info
