Solenoid plunger disassembly?
Discussion in 'Electrical' started by Bodeen, Oct 4, 2012.
  1. Bodeen
    4,647
    73
    222
    I took my solenoid plunger out and was going to turn the copper washer over and try to get some more life out of it. I cant get it apart to flip the washer. The manual doesn't say it comes apart, It shows it as one piece. Cant sell parts if they show how to fix it, I guess. I am smart enough to know that this thing isn't one piece. I did not want to beak out the Vise Grips and Channel Locks yet. I need to get to work tomorrow. Any tricks to getting it apart without destroying it?
  2. STEVE07
    4,128
    68
    86
    They are pressed together using a low impact press.You should be able to pull them apart twisting with a couple of pair of vise grips.When you get the washer turned set it upright on a metal bench and hammer the keeper back in.
  3. Bodeen
    4,647
    73
    222
    Thanks Steve. I got a feeling I better have a replacement on hand before I start the process. Seems like the Vice grips will scar up the plunger and the press fit may come apart.
  4. STEVE07
    4,128
    68
    86
    Jeff if you put cardboard on the plunger as a buffer the plunger should not score.A simple solution is just to use a bit of emory cloth on the face of the brass washer and not bother turning it around.
  5. Bodeen
    4,647
    73
    222
    I'll give it a shot. I did end up hitting the contact surfaces with emory cloth and slapping it back together. The disc side and the top contact on the inside have get some real craters in them. I will probably be rebuilding it soon anyway. Thanks for the tips.
  6. Rubyred
    Rubyred Senior Member
    1,020
    12
    Can I ask why you took it out or just doing some preventive maintenance? Thanks.
  7. Hoople
    Hoople Account Removed
    7,198
    34
    That piece is only available as part of an assembly on my bike. ($150 MSRP) ..
    I just love it.
  8. Bodeen
    4,647
    73
    222
    It needed some attention. Lots of pitting and cratering from arcing. Battery going bad caused some less than splendid starts that really beat on the contact surfaces. Starter dragging when started from a certain spot on the solenoid.
  9. Bodeen
    4,647
    73
    222
    Hoop, I saw the whole rebuild kit in J&P including the plunger for $35. Some cheaper.
  10. Hoople
    7,198
    34
    Wow your right. They have some nice looking complete kits for low $$. I don't see one listed for my 2009 FXDL but they have your bike covered.
    Now I know what I am going to say when the salesman says "time to trade. It's hard to get parts for the older bikes." :)
