RetroRocker
Hi to all from eastern UK
Went out to fire up my '07 Ultra Classic last evening for a cruise and all I got was a continuous, loud solenoid chatter and not much else. This bike did this to me a couple of years ago, just once, but then engaged and started after a rock back and forth and has never done it again 'til now and now it's permanent.
I have read the self help tips by glider on 'no cranking' and the 'how the solenoid works' but now I'm stuck.
Here's what I've tried ...
1. Battery terminals, both are clean and tight with petroleum jelly smeared for anti corrosion (have also remade these connections).
2. Have removed solenoid cover and looked at the big copper contact washer on the spindle and the contacts either side. These are not perfect but they are clean and not pitted or corroded ... just a little bit dull.
3. Battery voltage measured at 11.9 v.dc.
Very sudden onset of problem, no problem starting issues leading up to this before except that one episode I mentioned.
I would really be grateful for suggestions as to what to do next ?
thanks and best wishes
RetroRocker
RetroRocker
