soleniod problem
Discussion in 'Sportster Models' started by golfindodge, Aug 23, 2008.
  1. golfindodge
    golfindodge New Member
    3
    hey im new to this forum and new to the whole harley thing too. i just got a 72 sportster. I was told it is a 1100. it runs real good. but the starter hasnt worked. so i started to figure it out and the starter spins. so i went and got a soleniod for it. and i but the soleniod on and it still dont work. but then with i took the long spring out and it worked. but then the starter stayed engaged. i was wondering on what to do.
    thanks
    50
    Sounds more like the starter drive gone bad.
  3. golfindodge
    3
    well when i take a hot wire from the battary and put it on the starter it spins. and when i take the long spring out everything works but it stays engaged. its almost like the spring is grounding it out.
