SOFTTAIL HORN QUIT WORKING
Discussion in 'Softail Models' started by LEE WHITE, Jul 19, 2016.
  1. LEE WHITE
    LEE WHITE New Member
    3
    When i hit the horn button on my fatboy it only clicks. i changed out the horn and it is still only making a clicking sound?
  2. SledDog
    SledDog Senior Member Staff Member Moderator
    2,121
    68
    88
    Have you tried adjusting the sound screw on the back of the horn?
  3. Jack Klarich
    Rule out the horn by hot wiring it from a battery charger and grounding it
    Late model horns no longer have an adjustment screw, the older models that did have 1 were plastic and did not turn very good. Older horns were delco -remey, we used Cadillac horns to replace them, sounded great
  4. HDDon
    5,562
    133
    236
    Doesn't the horn have a relay?
  5. TQuentin1
    4,737
    142
    As said above, verify the horn works with jumper wires to the battery terminals. If the horn works, I would suspect the horn button on the grip. Unplug the horn and then measure the voltage across the leads coming to the horn. Have someone push the horn button and see if you get a "blip" of voltage on the meter and then nothing. If so, take the grip apart, disassemble the horn button, clean out any corrosion by-product, lube and reassemble. Should fix it.
    Cheers,
  6. Jeff Klarich
    4,844
    103
    496
    Mine did the same thing a couple years ago. I wiggled the wires and horn started to work again and no problems ever since. Must have been a loose or shorted wire. If you've changed horns and still have the same issue i'd follow what TQ suggested.
  7. LEE WHITE
    3
    Thanks a lot ! i got several good responses. i had taken off the horn and replaced it with another i had but when i hit the horn button the horn would only make a thump.I jumped wires to the horn from a battery and it tested good so i took off the switch cover and cleaned the switch connections and the horn started working.Should have checked the horn before replacing it but it was an easy try.A bad ground connection i guess.Again, thanx for the responses!
  8. Jeff Klarich
    4,844
    103
    496
    Thanks for the update, glad you got it figured out.
  9. SledDog
    2,121
    68
    88
    Goes to show you how long it's been since I replace a horn. I have air horns on both my HDs
