Softail standard 2005 air filter full of oil
Discussion in 'Softail Models' started by Benito1976, Mar 6, 2013.
  1. Benito1976
    Benito1976 Member
    40
    Hi fellow americans,
    I have a softail standard 2005 EFI. I don't use it every day, and after 5 -10 days at the first start everything runs well. 5-6 miles and some oil comes out from the air filter. In 4.000 miles I lost 1 litre in this way :bigsmiley30:...problems with the oil pump??? Dirty in the oil lines???? :newsmile077:
  2. Jack Klarich
    The softail oil tank sits higher than the oil pump causing oil to flood the crank case after sitting, this will cause the oil to build up and puke out of the air cleaner
  3. HDDon
    5,562
    133
    236
    Your softail has a checkvalve to prevent oil sumping. It could be that a piece of trash has caused the ball (check valve W/spring) not to seat and is allowing the oil to run down into the crankcase. In some cases the ball and or seat have become pitted and need to be replaced or the seat needs to be cleaned up (recut).
  4. 90FXRS
    90FXRS Junior Member Contributor
    462
    10
    If the bike sits for a period of time, when you start it do not hit the throttle for a couple of minutes. This should allow it to get the oil back into the tank and not puke it into the air cleaner.
  5. Benito1976
    Benito1976 Member
    40
    Thanks, but I dont know where this valve is :p. Is it on the cams plate???? :wall
  6. HDDon
    5,562
    133
    236
    If you don't have a manual now would be a good time to get one. The check valve on my '94FLSTC is the back screw on the top of the oil pump. Not sure where it is on your '05.
  7. tourbox
    tourbox Senior Member
    1,902
    173
    I don't believe the TC's have a check valve. The cam support does have a pressure relief valve w/ a spring that is removable. The Shovels and Evo's have the ball check valve that HDDON talks about.
    tourbox
  8. Jack Klarich
    :D Yup, The pump is now internal on the Twin Cam
  9. HDDon
    5,562
    133
    236
    Since the softail oil tank is still in the same place what keeps the oil from entering the crankcase?
  10. Benito1976
    Benito1976 Member
    40
    The oil pump mounted rear the camms plate and the camms plate provedides it
