Softail Rear Shock Replacement
Discussion in 'Softail Models' started by 90FXRS, Dec 27, 2010.
  1. 90FXRS
    90FXRS Junior Member Contributor
    462
    10
    I've looked through the self-help, tips forum but really didn't see a direct answer for my question. I've got all of the bolts cracked loose. Do I really need to lift the bike and all that to change the shocks? Couldn't I just leave it on the ground and do one at a time? The pre-loads are set and the shocks are ready to go on. The lift I have is the basic floorjack style and it appears it would be more of a hinderance than help. Thanks
  2. Mad Dog Jim
    Mad Dog Jim Banned
    605
    5
    I cheated. Floor jack to lift then two jack stands to hold it up but be careful...
  3. 90FXRS
    462
    10
    Y'all can disregard this question......found my answer.
  4. ProF
    ProF Junior Member
    508
    Don't leave us hanging....what did you do?
  5. 90FXRS
    462
    10
    Yes it can be done. Since the bike is on the ground there's not much room underneath so you will need that spline adaptor from Snap-On or something similar. First I cracked the bolts on the swingarm loose then took the nuts off the front. Removed one shock, put the new one on.....repeat for the other side. Went for a test ride and all is well.
    I found the adaptor, SRES24, on Ebay for $25.
