Smell of gas after riding.
Discussion in 'Touring Models' started by Rubbit, Dec 28, 2008.
  1. Rubbit
    Rubbit Member
    69
    A friend of mine with an 09 Road King said that when he gets done riding, he smells raw gas but no drops under bike or no obvious leaks. Does not matter if the tank is full or not, and no rhyme or reason to when it does it. Anybody else having this problem. 09 RG on the way and kind of wondering if HD has fixed the problem.
    50
    A couple of reasons why he may be smelling fuel, when the bike is shut off and the engine is hot, it acts like a radiator under the fuel tank and the fuel expands a bit causing vapors to escape through the vent system. As long as there are no visible leaks he should be OK but let the dealer check it out in any event.
    He's not the first to smell this either.
  3. whatyardwork
    whatyardwork Banned
    829
    4
    Stay away from the Taco joints.
  4. Bud White
    3,270
    As Glider says its the vent .. i was able to track it down on mine
  5. NEWHD74FAN
    8,191
    98
    19
    I don't have a bagger, but where is the vent hose where the vapors escape, is it in a bundle of hoses underneath say "below the swingarm pivot" or the like? Thanks! :)
  6. Bud White
    3,270
    Varies by machine i would guess.. mine runs down under the seat towards front of swingarm
  7. glider
    50
    Most all bikes vent most or all of the hoses in front of the rear tire at the lowest point.
  8. Rubbit
    Rubbit Member
    69
    the way i understand it on the 09 baggers they changed the vent or vent diaphragm which is why the 09 sometimes have that problem. my buddies bike is not dripping gas, the vent cap works as a one way valve to let air in as the gas is used, and the lower vent to works as a overflow, if i understand it correctly.
  9. buddybr
    buddybr Active Member
    217
    I noticed the raw gas smell on my 09 Ultra a few times when I first got it a couple of months ago. No leaks that I could see and was told it was the vent. Could be but now that I have a few miles, 3K, on the Ultra, I don't smell the gas anymore. I am thinking everything is seated and well sealed now.
  10. Knothead-Russ
    Knothead-Russ Member
    5
    Any solution?
    I started getting the gas smell at about 4500mi. I'm at 7500mi now and haven't noticed it as much lately, but it does still do it.
    (Been lurking for a while. Great forum. Great tips and info.)
