slip-on's
Discussion in 'Touring Models' started by ozzy, Jun 15, 2010.
  1. ozzy
    ozzy New Member
    4
    ok i know you folks are tired of the stage 1 junk but i just need some info . all i want to do is cool the bike down some and maybe get a little more power so are slip-on good enough for a stage 1 or do i need to go with the complete system. i have a 2009 uc by the way. got it new and love it but the heat is something elas in south east texas thanks
  2. Cleftwynd
    Cleftwynd Banned
    119
    Adding a free breathing exhaust to an already lean system won't cool it down IMO, adding fuel will though but that would require a tuner....
    For the best results I would recommend a full stage one including a tuner such as dynojet's, the bike will run smoother throughout the whole RPM range and most likely will run cooler due to the fact it isn't leaned out too much.
    Hobbit! you beat me by mere seconds... I guess I type too slow...lol
  3. glyd-n
    glyd-n Junior Member
    406
    The slip-ons will work fine with the stage one. There is no need to replace the whole system. Just make sure to get the fueler and intake.
  4. PeteINny
    PeteINny Active Member
    155
    Ozzy,
    I thought about the same thing and after allot of research it seems that a complete stage one is the only way to go. I just ordered Rinehart True duels. I still have to decide on a tuner and air cleaner. It just gets soooo expensive. I priced out a true duel set up with thunder max tuner and k and n air cleaner for $2600 installed. I guess I'll have to do it myself.
  5. ultrat
    ultrat Senior Member Contributor
    1,315
    Itll be fun, do it yourself & youll get to know your bike......
  6. PeteINny
    155
    Priced up the parts I wanted and it came to around $1800. Wow, $800 for labor?
