volvoman63
Good day all...quick question. If I put Rush Slip-Ons on my 09 Street Glide do I have to re-map?
Does it matter what size baffles when just adding the slip ons.Tought question.
If the bike was a pre 2009 I would with out a say right out add fule some how and recommend just doing the full stgae 1 and add a TFI.
But you have a 2009 The dealer I go to an trust fully had told me many times now on the 2009 it is just not need, they have test many of them and found the 2009 can adjust to the chnage with no problem.
In any case a TFi is not a bad idea if it does not break the bank and the your ready to do your full stgae one anyway. IMO
I went with the rush slip-on with 1.5 baffle. Are these slip-ons compatible if I decide to go with true duals?FWI
When going to true duals, It's VERY important to find out if you have a pair of mufflers that they are meant for true duals unlike the stock mufflers mentioned above that have the left muffler basically as a sound enhancement chamber with little flow. Using these mufflers on a true dual system will damage the engine when going to true dual head pipes.
