free website stats program slight misfire | Harley Davidson Forums
slight misfire
nascar7613
2006 Road King fuel injected, no modifications. When running down the road at a steady speed and fairly low RPM, say around 2500, every once in a while the bike will have a very sudden and slight misfire. It will rerpeat this randomly. I wish I could make the noise for you. It doesn't seem to do it until the bike is warmed up. Changed the plugs and wires, no difference.
Might start by checking for DTC's.
http://www.hdtimeline.com/archive/t-728.html
When this happens are you losing losing power to the lights, speedo or anything else that may be noticeable or is it just making the misfire with no other noticeable conditions? Also what modifications, if any, have been done to the bike and did this possibly start after any recent mod was performed?
I would ask? How do you know the speed RPM of the motor?
Could it be the miss is from a Little lugging?
What gear and what speed on the odometer does the miss happen... this will tell me more than a guess at the RPM.
I don't doubt your ability to judge RPM but Speed and Gear is easier to supply accurately for us... IF you go slow enough in a gear and Not doing the RPM you think, it may be the problem.:D
Warm the bike up (riding it) then carefully work your hand in to the injectors and grab the injector wires about an inch from the plug. With the engine running at a fast idle (2k), wiggle the wires on each injector (separately) and see if you can replicate the missing symptoms. If so, you probably have a bad (cracked or broken) wire and will need to fix that.
Harley Davidson Community
no modifications.
No modifications? Not even fuel enrichment of any kind? Does your bike have O2 sensors? How many miles on the bike. The bike was running fine and then this started suddenly? When you feel the miss,, if you applied more throttle, does the bike pull fine without a miss? This engine miss is ONLY at steady state throttle?,, starts fine,,idles fine,,acceleration to get on interstate is ok?
The bike does not have 02 sensors or fuel enrichment. It has 43000 miles. The problem came on gradually, every once in a while I would feel something that felt like a miss, now it is every time I ride it after it is warmed up I can feel and hear it. It starts fine, idles fine and when I accelerate there is no miss, only at steady throttle .
Could be 1 of several things but where I would start....
Since it does not happen during mixture enrichment times (warm up w/ extended injector duration or "choke" times), it almost points to a lean fuel issue or a lean miss. As soon as the warm-up enrichment period ends, the bike experiences the miss.
Something like lower than normal fuel pump pressure, a small air intake leak, 1 injector having a poor fuel spray pattern, fuel filter having poor flow, a pin hole leak in the Hi pressure fuel pump line inside tank, etc. Something that creates a leaner than normal mixture. Anyone of these issues usually gets worse with time, just like your problem has.
For now I would rule out electrical or ignition since it does not happen under hard acceleration. That's the time when the ignition system is under highest demand.
Hoople has got you started in the right direction. Definitely sounds like a lean issue. If it were a Johnson outboard, I would say it is running perfect.
Along with Hooples great advice have a look here also Harley Davidson Community
