Here's some pictures that will show the installation of a grease fitting into the housing for the shifter shaft. A very simple thing to do with basic tools. It requires a drill, tap for the size fitting being used and a grease gun. First remove the shaft and then you can proceed with the drilling and taping process.
This has been a common problem from lack of maintenance in this area and riding in the rain and washing will make it worse because it washes away the lubrication for the shaft.
Symptoms are the shifter will not return to the proper position between shifts and seems to hang up or bind.
Removal of the shifter shaft that the shifter pegs are mounted to and cleaning it with some very fine sandpaper then the installation of this grease fitting and a greasing and reassembly will usually cure the problem.
A greasing at the major services will keep the shifter working smooth.
Drilling the hole
Cutting the threads
Zerk fitting installed
One thing I should have added here is that some riders experience a problem with the shifter while riding that the shift arm does not return to the center position on it's own after a shift. The usual cause of this is the shifter shaft needing to be removed , cleaned and re greased where it goes through the boss that holds it on the bike. From constant washing/riding in the rain over the years the factory grease washes out and makes the shaft bind and this is why it doesn't return on it's own. Many have thought it was a transmission problem when in fact it is a maintenance problem only.
Drilling the hole
Cutting the threads
