J jenkie0 New Member Sep 27, 2009 #1 Does anyone know about a Springer 2006 FXSTS? We've replaced the handle bars and when we went to crack it it won't. It shows a key symbol.
Bud White Well-Known Member Retired Moderators Sep 27, 2009 #2 key symbol is the alarm if you have one .. do you have a keyfob ?
G glider Veteran Member Sep 28, 2009 #6 Did you do internal wiring or did you disconnect the bar switches? A bit more info may get you an answer to your question.
