seat removal 2010 Electra Glide CVO
Discussion in 'General Harley Davidson Topic' started by Rob Sundstrom, Jun 21, 2011.
  1. Rob Sundstrom
    Rob Sundstrom New Member
    3
    Sounds like a stupid question, but I cannot figure out how to remove teh seat on my Electra glide CVO to install a battery tender.
  2. Dr. Dolittle
    6,404
    118
    29
    Should be covered in the owner's manual. If you don't have that:
    1. Unscrew the knurled bolt behind the seat holding the rear portion to the fender.
    2. Slide the seat backwards to get the flange loose from under the gas tank.
    3. Remove seat.
    This is how it works on my FLHX so yours should be the same unless Ultras are different.
  3. rjsogard
    rjsogard Member
    76
    I think he is having problems with the cross over strap of the seat maybe?
  4. glider
    50
    That's possible. If you just disconnect one end by removing the bolt the strap is out of the way then.
  5. Dr. Dolittle
    6,404
    118
    29
    Duh - thanks for adding that! I took my strap off so I totally forgot about that step.
  6. glider
    50
    I did too. That was the first thing that came off when I got it home.:D
