SE Slip ons
Discussion in 'Touring Models' started by ickysticky74, Apr 17, 2011.
  1. ickysticky74
    ickysticky74 Active Member
    111
    Has anybody altered the baffles on the SE slip ons? If you did does it mess up the back compression?
  2. lv2ride56
    lv2ride56 Member
    38
    Didn't alter the baffle itself but did remove the converter. Seems to run much cooler but changed headpipes at same time. Sound iproved also.
  3. SixPak
    SixPak Junior Member
    418
    38
    10
    I removed the built in cat and also removed the fiberglass packing. Didn't notice any temp difference, but sounds much better and seems to pull a bit better. Mine are on an ST.
  4. Jack Klarich
    You can play with the baffles and not get in to too much trouble IMO, I have made exhaust splitters for back pressure issues while running fish tail drags on Baggers and had good results:s
  5. ultra...good
    ultra...good Banned
    302
  6. ickysticky74
    111
    Not sure how long they have been on. I got the bike in January 2011 with 4,200 miles on it. It was already opened up and had the SE slip ons. I just put am K&N air filter on it and took the bell cover off the air cleaner..
