SE pipes
Discussion in 'Engine, Fuel and Exhaust' started by salsero67, Jan 23, 2011.
  1. salsero67
    salsero67 New Member
    I have an '08 Road King with SE pipes, tooooo quite for my taste. will removing the baffles be the best option? are there any replacement baffles to get more sound out of my pipes? Thanks, Hector
  2. Jack Klarich
    Removing the baffles you will lose back pressure and scavenging Big City Thunder - Are You Baffled? check this out:s
  3. salsero67
    LOL! I figure that, i guess I'll give it time and go with the 3-1/2 slip ons
  4. NEWHD74FAN
    8,191
    98
    19
    Good call to go with slipons, save the H-D SE ones if they have the EPA sound cert/numbers on them. As regulations tighten up, you may need to "slip them on" to get bike thru...:s
  5. Breeze3at
    Breeze3at Well-Known Member
    4,923
    224
    Cycle Shack, makes S.E. repl. baffles. Give them a look.
  6. glyd-n
    glyd-n Junior Member
    406
    I have the SE slip-ons with the baffles removed. Installed BCT Header baffles and the sound is outstanding. It has a deep rumble, not overly loud but it will set off alarms and they WILL hear you coming.:D:D
  7. IR Rick
    IR Rick Active Member
    167
    Check out Fullsec
    Steve will take care of you:p
  8. ultra...good
    ultra...good Banned
    302
    Where are you located? I've got a SE slip on set that are just a bit too loud for me. Might be willing to trade.
