SE Compensator Kit
Discussion in 'Touring Models' started by kb5zqd, May 31, 2010.
  1. kb5zqd
    kb5zqd Member
    7
    About to replace my OEM compensator. Does the new SE come with the revised Nut or do I need to order it also? Does anyone have the Gasket # for the inner primary to case? I have read the posts on this and feel confident I can do it. I will probably order the locking tool also.
    Thanks
    kb5zqd
  2. Hoople
    Hoople Account Removed
    7,198
    34
    The SE kit comes with the correct nut/bolt. The gasket (at least on mine) was not like an ordinary gasket. It was made of metal with a rubber insert. I had a new gasket on hand but once I saw what it looked like, I reused the oil gasket with no problems. If in doubt you can always apply a very thin light coat of Indian shellac to the mating surfaces. It won't leak after that.
  3. geezer
    geezer Senior Member Contributor
    1,709
    68
    73
    I did the same as Hoople, reused the old gasket. I had a new one but saved it for next time. They're about $40.00 up here. Just make your own locking tool. The self help section has several ways guys made it themselves.
  4. Hoople
    7,198
    34
    Wow. I paid $11.16 for mine. Wanna go in business? "UnderGround Gaskets Incorporated":p
  5. Bodeen
    4,647
    73
    222
    Save the $$ on the locking tool. I used a block of wood! Worked for me, cant see it being any different than using "the tool". My inner primary gasket is an o-ring. Difference in year, I guess.
    Bodeen
  6. RibEye
    RibEye Junior Member
    993
    61
    Maybe I'm thick, but, why do you need the gasket for the inner primary to case if all you are replacing is the compensator? You should not need to remove the inner primary unless you are going after the stator or shaft seals.
    Enjoy,
    Rich P
  7. ultrat
    ultrat Senior Member Contributor
    1,315
    i think there saying between outer & inner primary i used a new one only because i bought one..
  8. Hoople
    7,198
    34
    If you don't want to do the grinding thing, to get the rotor off you must remove the inner primary. You must change the rotor if you install a SE compensator.
  9. kb5zqd
    kb5zqd Member
    7
    Thought while was there I would put Chrome inner primary on.
  10. Bud White
    3,270
    Wood will for for locking primary i bought the tool my self and you dont have to use a new gasket if it doesnt split mine did..
