This would be a case were changing out compensator would pay off in the long run
Why would you replace a perfectly good trans with a Baker? That makes no sense .
And that's where I am. I guess I should be able to get it not to leak when I'm building my new S&S engine for it (sometimes I think my scoot thinks she is an early shovel - while she's just a teenager!)some times i think it was nicer working with the old bikes, just jet the carb or put the old gasket back in,, it was going to leak anyway.
Ride more read less there is not one thing wrong with your Hd gear box and good chance it will out last you
I'm thinking of going with 103 kit out of the SE Catalog $2300
also add the hd cam plat. roller tapits
VH Header pipes
anything i should be adding?:s or what would do differnat
I have the tunner, and the mufflers, & Vo2 a/c,
Thanks for the help:57:
I would talk to Steve at GMR Performance about one of his 107 kits. You could have a build that would better suite a bagger for street use than the Stage IV SE 103 package. How does 120 ftlb of torque and 106 hp, 100 ftlb of torque and above from 2100-5500 rpm sound?
Twin Cam Performance Packages
I would take this over the SE package any day.
Randall
