screaming eagle cam plate and oil pump
Discussion in 'Engine, Fuel and Exhaust' started by robotoroadracer, Apr 7, 2009.
  1. robotoroadracer
    robotoroadracer Member
    38
    Is there a thread out there on installing the new style HD cam plate w/hydraulic chain tensioner and oil pump? Did a search but didn't come up with anything...maybe I'm not typing in the right info...thanks in advance!
  3. robotoroadracer
    38
    I knew I could count on you, thanks again glider!
  4. hntwrobin
    hntwrobin Active Member
    236
    Be careful when you install the pump follow the instructions in the manual so you don't screw up the pump. The directions are great if you follow them.:newsmile045:
