Schaeffers Supreme 5w-50 oil
Discussion in 'Oil' started by rossn2, Mar 9, 2011.
  1. rossn2
    rossn2 Member
    46
    Anyone tried either the Supreme 7000 20w-50 or Supreme 9000 5w-50 oil in their bike?
    I just ordered a case of the 9000 to try in my 2011 FLHTK engine and primary. Will continue to run Amsoil 75-110 (SVT) in the tranny.
    I wouldn't run any 5w-50 in a harley or larger air cooled engine. 20/50 is all I would use.
  3. BUBBIE
    BUBBIE Well-Known Member
    4,974
    125
    YEP Glider is Right On Here as ALWAYS.. !!
    May I add my thoughts:
    The 5w IS the weight OF the oil, and NEVER will get Heavier than THAT...IT will REMAIN a 5W all the way Thru raising temps that a 50 weight takes to BECOME a 5w oil. The LIGHTEST oil that is recommended for a HD is 20w50 and 5w WILL result in damage to the motor IMO.... Way TOO THIN.(.)
  4. Jack Klarich
    Bubbie and Glider are right here, while Honda and Toyota want to use 0-20 oils in water cooled they can get away with it, but not in an air cooled motor:s
  5. doctordoug
    doctordoug Account Removed
    137
    I wouldn't experiment with an untried oil in my expensive new Harley. I use Spectro Platinum 20-50 in the engine, Spectro HD primary oil and their 6 speed oil in the tranny. Redline is also great for the transmission. I'll let some one else try the "new" oil.
  6. rossn2
    rossn2 Member
    46
    Hum, isn't the first number 5w, the cold crankability of the oil? And, doesn't have anything to do with 50w thinning out to 5w?
  7. ultra...good
    ultra...good Banned
    302
    Thats what I was always led to believe as well. 5w til it warms up, then its 50w. In my manual it recomends to use 10w40 in weather below 40F. Thats on the 99 ultra.
  8. BUBBIE
    4,974
    125
    OKAY, this is what I meant...
    You have a 5w, yes that is a 5 weight oil.... Never any heavier.... the 50 relationship tells you ONLY How Long the 5w Will stay-remain a 5w as compared to the 50 weight oil as it is Heated....
    So IF you take a straight 50w and HEAT it up until it Becomes a 5 weight, that is the amount of Heat protection you have Using the 5w oil....
    This Shows that 50w, Heated to the MAX temp. it takes to make the 50w INTO a 5w oil.
    This Is used JUST to compare the 50 weight (how long the 5w will REMAIN a 5w when Heated) BUT Never will the 5w become a 50w oil JUST will remain the 5w it is. 5w50
    If you HEAT a 50w oil Hot enough to become a 4w oil...... That is the same amount of Heat it will take to make the 5w into a 4w ALSO.= comparison only here..
    Now COLD works the other way
    IF a 5w get cold enough it WILL become a 50w and pour like a 50 weight.... at that temp, but IF you compare it to a 50 weight at the same COLD temperature, the 50w will not pour like the 5w, even when it is the same COLD temp..
    that is MY take on this..
    They put molecules into the oil to KEEP IT at a 5w.....
    NO matter what the last number is, 50, 60, 80, The oil WILL be a 5w
    When it gets warm it is a 5w and when it gets HOT, it is a 5w... UNTIL it gets TOO HOT.... Then it Will start to FALL Under the 5w number.
    PHeeewww
  9. Fossil
    Fossil Active Member
    335
    What ever happened to the common sense of using only oils specified for V twin motorcycles. Late model Harleys cost a lot of money and I read time and again how some one is trying to buy cheaper oil, spark plugs, oil filters, etc. You guys have that much money that you can experiment with your Harleys?
  10. ultra...good
    ultra...good Banned
    302
    ummmmmmm yep..............
