Fourdogs; The way I got my bags leveled was to remove the QD pins, and make sure the bags are sitting on the bottom support correctly. Then I had wife push on each bag until it looked straight. I then loosened the two bolts on each QD wire bracket and moved the brackets to align with the pins. It took a little fiddling, not bad. BE CAREFUL that you don't adjust the bag too far forward that it contacts the side cover.
If the above doesn't work, check the alignment of your rear crash bars and bag guards. They can also be moved a small amount to level the bags.
