free website stats program S&S carb main air bleed | Harley Davidson Forums
macmic87
S&S carb main air bleed in an e series carb is the earlier fixed orifice. has anyone drilled and tapped to use main jets to adjust the air bleed?
That is one of the aspects of a Thunderjet.
That air bleed is external, and the hole inside the bowl is plugged via the use of a screw provived in that kit.
Can you drill/tap that air bleed hole? Sure.
