ogri Member Feb 28, 2010 #1 i just went to swap my standard air cleaner for a screaming eagle one . what do i do with the wires on the back of the air box ??
G glider Veteran Member Feb 28, 2010 #3 Tie them off with a cable tie so they don't end up on the pipes and melt. You'll probably set a code without a resister in the plug.
ogri Member Feb 28, 2010 #4 thank you both for that , what are these codes i've heard so much about ??
Big Rol Active Member Feb 28, 2010 #5 Same as the error cdes on a cage, bike lets you know if something isn't right.
Hoople Account Removed Feb 28, 2010 #6 Interesting. Is that value only on a UK bike. I don't own a FXDF but I don't see any on the back of my U.S. FXDL.
