Right out of the crate. SE A/C. D&D Fat Cat with performance baffle. 58mm throttle body. 10:5 to 1.
I'm thinking of putting the 120R in my 09 What did you do and what would you change or add at the time you have verything down?
I already have pipes and A/C and Tunner
Sorry it took so long. I went with what HD basically recommended in their catalogue. Auto compression release, 58 mm throttle body which will require a bigger backing plate, larger fuel injectors, SEST.
You can use any fuel tuner you want (sest, tts, etc). You have to get it tuned by someone that knows right away. Trust me. The canned map from HD was dangerously lean.
I wouldn't recommend the SE clutch as it is way stiff.
