rusty front caliper bolts
Discussion in 'Touring Models' started by billyd1, Jul 16, 2010.
  1. billyd1
    billyd1 Active Member
    194
    Hello ladies and gents. I want to replace the rusty front caliper bolts on my '09 RKC. Should I go stainless steel or chrome? Where's the best place to get them?
  2. Breeze3at
    Breeze3at Well-Known Member
    4,926
    224
    IMO stainless stays nice longer, BUT most stainless is not graded for strength.
    Unless you can find purpose made ss rotor bolts, I'd go with chrome. Russell and Colony are good suppliers.
  3. Jack Klarich
    If you go chrome, be sure to chase the threads for burs, and I would use loctite and a torque wrench:D
  4. billyd1
    194
    Thanks gentlemen. Alloyboltz it is Smitty your the man! Should I use red or blue loctite? My instincts say red.
  5. NEWHD74FAN
    8,191
    98
    19
    In other words stick with Blue loctite as Smitty said (you do want to be able to remove a fastener without having to heat parts); and after chasing or cleaning the threads as Jack said to prevent galling or crossthreading...
  6. Gator454
    Gator454 Active Member
    165
    Hello Smitty901,
    I just checked out that link to the polished bolt site. From what I have seen the prices are real good and they are graded bolts.
    Thanks,
    Gator
  7. glimmerman
    glimmerman Active Member
    356
    working with stainless all day, i personally, would never use stainless anywhere heat is involved. stainless steel, austentic grades 304,308, 310, 316, tend to seize and gall causing tremendous problems. compounding this is an aluminum caliper prone to road debris corrossion and the need for a threadlocking compound-loctite. i NEVER use a stainless fastener without a good grade of bostick never-seez. note trade name. in my opinion stainless is best relegated to industrial uses for piping or machinery where corrosion resisantance is needed. please also remember-stainless is just that. a stain resistant steel. get a good grade 5 to 8 chrome plated fastener and use the loctite. sleep well knowing it will come out later.
  8. glider
    50
    Great info and to add one thing the grades of stainless DO NOT coincide with those of the regular steel bolts.
