Running and Stop light in rear Turn Signal.
Discussion in 'Electrical' started by RicardoJPinto, Aug 20, 2009.
  1. RicardoJPinto
    RicardoJPinto Account Removed
    27
    Hi guys
    My next mod will be lateral license plate and chop the stoplight with H-D Aux Running, Brake Light, Turn Signal Kit 69463-06.
    In Portugal this kit is expensive, do I have other way to put my stop and running Light in the turn Signal?
    I’m thinking use LED lamps in turn signal, witch one shall I choose?
    Thank you all.
  2. jerrybombard
    jerrybombard Active Member
    115
    I can't imagine why no one has charmed in on this. Maybe put it in your type of bike catagory, like touring?
    anyway, I'm not sure trying to do this yourself is wise. I'm sure it can be done, though. The LEDs will require an equalizer if used. And with the ECM's and such, you may end up paying a much higher price trying to save some money.
    I just added the HD kit to my RKC and think it's great. I noticed other bikes on the way back from biketober fest a few weeks ago had the R/T/B kit and that made up my mind. Much more noticable than just the single light.
    The kit takes all of 5 minutes to install, most of that time is removing the seat.
    I got mine from Zanottimotor.com for $46 + shipping, got here in 3 days or so. I don't know what your exchange rate is, but I would go for the kit.
    Kuryakin makes an LED kit you might want to take a look at. It's only a few $ more.
  3. harley@16
    harley@16 Junior Member
    483
    5
  4. Drumrguy
    Drumrguy Account Removed
    573
    I would use the Harley kit. Some times aftermarket stuff just is not worth it.
  5. RicardoJPinto
    27
    Yes I think that way too, I will put original kit.
  6. NEWHD74FAN
    8,191
    98
    19
    Simplicity is always nice, and if HD has a retrofit kit that works, why not try it if you do not want to affect warranty and are only interested in turn key operation.
    The good news is, these kits are tested and working by plenty of users and if there were any nits, they would have been worked out a long time ago.
