run stop switch
Discussion in 'Electrical' started by bubbacat, May 23, 2014.
  1. bubbacat
    bubbacat Member
    6
    can anyone help me I'm at my wits end > I have a 83 Shovel -Lowrider and my Harley ignition took a dump so I put in a Dayton twin tech ignition and I cut all the Harley ignition wires out and just used the new ignitions wire > my problem is I lost my run stop switch on the controls and I took it apart and there is just 3 wires a white and a grey and a black .can anyone tell me how to hook it back up so I can shut off engine from the bars instead of the key :)
    thanks for any advice I could sure use some
  2. tourbox
    tourbox Senior Member
    1,886
    168
    The white should go to the the coil to give power to the original ECM. The grey should be coming from the Ign. circuit breaker. The black should go to the starter relay. There should be a white jumper from the Run/Kill switch to the Starter button..
    tourbox
  3. bubbacat
    bubbacat Member
    6
    thnx tourbox > thats what i did wrong i ran the new ignition from one of my relays instead of the white wire coming out of the run/stop wiring . i feel kinda stupid cause i didnt put 2 and 2 togeather . i musta had a hard nite tipping em back lol thank you so much for your help
    god bless and ride save
  4. hobo55
    hobo55 Active Member
    306
    Glad you got it. good on you.
  5. tourbox
    1,886
    168
    You're welcome. Glad I could help.
    tourbox
  6. bubbacat
    bubbacat Member
    6
    thanks to everyone who helped and also ones who couldnt i appreciate it very much > sometimes we over look the obvious things or just have a Brain Fart lol
