RPM Tester
Discussion in 'General OFF TOPIC' started by Goofuss, Sep 14, 2009.
  1. Goofuss
    Goofuss Active Member
    131
    I finally got my TFI put on and set to their settings. I want to dial it in a bit more. They say to start at 1800 rpm. Now I do not have a tack. How good are the rpm testers? Are the ones for around $25 worth it?
  2. Bud White
    3,270
    depends some work some dont .. if ya can find someone who has a timing light with RPM built in they work lot better
  3. glider
    Don't go crazy, estimate it, you'll see the difference as you dial it in anyway. 1800-2000 should be easy enough to estimate and it's not that critical.
  4. Goofuss
    131
    Thanks!
