Can't find mid range stumble. Have changed TPS and MAP sensor. Problem seems to be worsening. Recent engine rebuild with Screaming Eagle 95", MC Gerolomy Heads, stage II Screaming cams, Thunder Header and Power Commander. Have played with different mapping but still stumbles and seems to be starting to pop at low end. What would set a PO108 code other than sensor failure?
