Mongo44
Hey y'all! Been awhile since I've posted anything here as my bike has been out of commission for awhile, but thankfully, she's back on the road. Well, she was until I messed things up!!
Okay, my bike is a 1995 FLSTN (Evo 80")...
Several nights ago, I decided to inspect my tappet screen. I have an Oil Pressure gauge that mounts to the back right rear Rocker Box bolt. I removed this to allow for easier removal of the Tappet access bolt as the cable running to the gauge would twist up too much as I turned the bolt.
Anyway, in the process of re-installing the RB bolt, I accidentally over-torqued it and stripped the inner threads.
After slapping myself on the back of the neck and head a few times, I accepted my mistake and set about finding a solution. What I will probably do is get a "Time Sert" threaded insert and go from there.
However, I have a question or two. Last night, I inserted a "depth gauge" to see how deep the hole is. It is, from the RB surface to the bottom of the hole, about 1/4" deeper than the length of the threaded part of the bolt. When the gauge is installed along with the accompanying washer, it takes up maybe another 1/4" of the bolt length. So, in essence, I believe there to be around a 1/2" of non-stripped threading in the hole.
My first question is, Does that threaded hole (in the bottom RB plate) have a bottom, or is my depth gauge going completely through it and reaching something else? I was thinking about getting a longer bolt as a temporary fix, but don't want it protruding into a space where it might get sheered-off or cause damage to another internal (moving) part.
My second question is, Would this provide ample grip to hold the RB in place at the recommended torque value (10-13 ft-lbs)?
Any advice is greatly appreciated! Thanks!
