free website stats program Road King Wheels | Harley Davidson Forums
Road King Wheels
Rider63
Hello al I have a question.
Will the wheels and tires of a 2010 Road King fit a 2006 Road King?
Thanks...
Fisrt, welcome to the forum. There are some very knowing folks here. Now to your question. Check the wheel and tire sizes. Then check the width of the hub. The bearings should be the same size, but ask your dealer. You should be able to determine the answer at this point. :s You may need to trim the spacers a little or not. It is not a difficult process, just check your dimensions first. I put ElectraGlide wheels on a Heritage Softail after some checking and bearing change. Good lusk on your search.
Basically no. But with enough money anything can be made to fit. Your '06 axle is 1", '08 and up is 25mm, but bearings can be changed. The biggest problem is your rear rim is 3.50" for the MU85 5 1/2" wide tire. The newer rear rim is 5.00" wide for the 7" tire. Your swingarm and fender won't allow that much rubber. Front has about the same problems.
