Road King rider in Manchester UK
Discussion in 'New Member Introduction' started by JOHNNYREDPEN, Feb 2, 2014.
  1. JOHNNYREDPEN
    JOHNNYREDPEN Member
    32
    18
    Hi everyone. I just found the Forum site and signed up. There is soooooooooooo much useful information here. Brilliant. I look forward to learning from you all. My bike is a 2009 Road King. I,ve had it since new and I love it. However my ABS light is staying on and someone told me I can access diagnostic codes through the speedometer. Can anyone please tell me how to do that? Thanks and I look forward to reading many more useful bits of information. JOHNNYREDPEN:D
  2. Jack Klarich
  3. fin_676
    5,788
    153
    287
    Welcome to the forum
  4. JOHNNYREDPEN
    JOHNNYREDPEN Member
    32
    18
    Thanks Capital Jack. I,ve only been a member half an hour and learned loads already. JRP
  5. Jack Klarich
    C0562 Device voltage low
    C0563 System voltage high
    C1014 ECU internal fault
    C1017 Pump motor power circuit open fault
    C1018 Pump motor ground high resistance fault
    C1021 Front wheel speed sensor equals 0
    C1023 Rear wheel speed sensor equals 0
    C1025 Front wheel speed signal intermittent
    C1027 Rear wheel speed signal intermittent
    C1032 Front wheel speed sensor circuit open or shorted
    C1034 Rear wheel speed sensor circuit open or shorted
    C1042 Pump motor open
    C1043 Pump motor stalled
    C1055 ECU internal fault
    C1056 ECU internal fault
    C1057 ECU internal fault
    C1061 ECU internal fault
    C1062 ECU internal fault
    C1065 ECU internal fault
    C1066 ECU internal fault
    C1094 Front brake switch always on
    C1095 Front brake switch open
    C1118 ECU internal fault
    C1121 ECU internal fault
    C1151 Front wheel release too long
    C1153 Rear wheel release too long
    C1158 Calibration programming required
    C1206 Wheel speed sensor frequency out of range
    C1208 Wheel speed sensor frequency out of range
    C1212 Front or rear brake not applied with decel
    C1214 Rear brake switch always on
    C1216 Rear brake switch open
    U1300 Serial data low
    U1301 Serial data open/high
    Here is some more info for you, let us know what you find:s
  6. tourbox
    tourbox Senior Member
    1,902
    173
    Welcome from So. Texas.
    tourbox
  7. oldhippie
    oldhippie Senior Member
    1,122
    68
    43
    Welcome to the forum.:cheers
  8. bikerod
    bikerod Member
    36
    welcome to this great forum bud. Rod UK.
  9. Joyflyin
    Joyflyin Experienced Member Staff Member Moderator
    5,823
    133
    208
    Welcome aboard, glad to have you here. :ws
  10. Bodeen
    4,647
    73
    222
    Glad to have you aboard! :ws:rider
    From Central Florida.
