free website stats program Road King Classic Starter Installation Error? | Harley Davidson Forums
chris49
Eperienced a grinding noise in primary case, close to starter. removed the primary cover all clean, no shavings, no broken parts. suspected starter was engaging sporadically (rebuilt) installed new HD starter. reassembled, with minor adjustment to chain tnsioner. But when starter button is pressed, just a single "click." No heavy drag on battery (new) concerned i overtightened bolt on jackshaft in primary case? what did i do wrong?
Start by checking the battery terminals, a bad connection will give you just a click. No doubt you removed them while doing the job.
