Road Glide problem
Discussion in 'Touring Models' started by Redfish-Joe, Jun 17, 2009.
  1. Redfish-Joe
    Redfish-Joe Senior Member
    2,307
    10
    My nephews 02 carbureted RG was running good till he shut it off for a few minutes. He started it up and it spit back and died. Got it started again and ran really rough. I wasn't there but he made no mention of any unusual noise. With over 50k on the clock I am willing to bet the tensioners went south and the timing is off. I am going to look at it tomorrow, check the plugs and run a compression test and open the cam chest. Any other suggestions that may save some time troubleshooting? Thanks to all!!
  2. TQuentin1
    4,737
    142
    Check codes.
  3. glider
  4. Redfish-Joe
    2,307
    10
    This is a carburated bike. Will the codes be the same and are they accessed the same way? Thanks...Joe
  5. glider
    It should bring up the codes Joe.
    More than likely it's a sensor going/gone bad.
