Road Glide Electrical Problem
Discussion in 'General Harley Davidson Topic' started by Kurtis, Jun 11, 2015.
  1. Kurtis
    Kurtis Member
    6
    I turned my bike off to get gas. When I turned it back on, I had no gauges or running or tail/brake lights. Does anyone have any idea what mad the bike do this bad thing?
  2. tourbox
    tourbox Senior Member
    1,886
    168
    It could be your Main fuse, large 40 or 50 amp fuse. I sometimes don't turn the switch knob far enough and have the same issue. I cycle it off then back on for a good go. Did you try that or have to be trailered home?
    tourbox
  3. Bodeen
    4,643
    73
    221
    Check the acc. fuse. On my Road King, when the acc. fuse blows the speedo, turns and brake light quit. If the fuse is blown check the front fender tip light if present.
  4. Kurtis
    Kurtis Member
    6
    It is an 04. The fuses are OK. I did not find a 40 or 50 amp though. The bike runs, just no running lights or instruments or brake lights.
  5. Bodeen
    4,643
    73
    221
    Did you check all the fuses behind the left side panel? Pull all the fuses and inspect sockets for corrosion etc.
  6. Kurtis
    Kurtis Member
    6
    The information so far has been helpful. The alarm was wired out before I got the
    motorcycle. I used the provided instructions for retrieving the codes. The
    odometer shows up as well as the key icon, but no codes or speedometer sweep.
    The engine starts and runs well, the accessory driving lights work as well as
    the blinkers and stereo. The issue is with the gauges, speedometer, tachometer,
    running and brake lights. Do you have an ideas where to find the problem causing
    these issues? :small3d023:
  7. Breeze3at
    Breeze3at Well-Known Member
    4,923
    224
    There is a "instruments" fuse. I believe it's the top right one, but the cover on your fuse box will tell you. Did you check the fuses with a meter, or look at them? Looking is not an accurate way to determine good or bad.
  8. Kurtis
    Kurtis Member
    6
    Thank you for your information. Yes, I used an Ohmmeter. The only 'dead' fuse is the one marked 'lights'. The Speedometer, Tachometer, Headlights and Turn Signals all work. What is out is the Brake Light, Speedometer, Tachometer and all of the gauges.
